Heres the pump. Has some scaring but don't think that would cause an instant loss of pressure. Maybe a gradual loss. Shaft is tight in the rotor.
It had 60psi at idle before this.
How are you checking the shaft on the rotor fit by hand ? Same goes for the drive.
Put one end in a vice and vise grips tight on the shaft ...
