Well on the way home from work today I noticed my oil pressure guage was stuck between the normal position and the High line...When I pulled into my parking lot and let it idle it still stayed there...I shut the truck off and then started it again and its still stuck in the same spot...anyone else ever have this problem and if so what was the cause? Could it be the sending unit or guage its self?
