My rocky's got the Airwolfs but I have a low lift Broomstick cam that doesn't really take advantage of them.
The 414 went a real easy 11.16 @ 119 in my 3000 lb w/d Rocky with a slow-n-easy 1.69 60' time. Same motor/drivetrain would likely go 10.70's at 123+ in my old Duster or Dart at the same weight even with the .585/.570 (gross, maybe .545/.530 net) 1.5 rocker cam. I like them but the Rocky's .65 Drag coefficient is not gonna show you the ET's they're capable of.
I bought them since they were a net $500.00 upgrade from my old SDSS Ported eddies that were just a little too small port wise for the 440" I was planning.
Not real promising from the look of it( the airwolfs)
As an example I used to have a 3450 pound combo that went 10.74 with mildly ported eddies( peak flow 274@600) and a comp flat tappet that was 598/623 with with 1.6 rockers I used. This with a 727. So with the airwolfs fully ported and in a 400 pound + lighter car and not running even the above ET, they seem down on power. The above 10.74 was at about 124 with the small Tti step headers and muffs at 11.5 ish compression fwiw.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
