In my opinion, strut rod bushings should be rubber or heim joints. The way the strut rod/K-frame interface is constructed, the bushing must compress and de-compress with each up/down movement of the suspension. Poly is not compressible enough for this task.
When using 6061 T6 aluminum strut rods, I observed flexing of the strut rod when used with poly bushings, but not with rubber bushings.
I reccommend that you cancel the order for poly, and get rubber.
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
