There is no seal. The trim ring lays directly on to the 1/4 panel sheet metal. Do you have a repro 1/4?
If so, sounds like the gas cap opening on the 1/4 may not be shaped properly. The repro 1/4's are notorious for that.
The car has the original quarters and it is a NOS gas cap. Looks like I will take it back off and see what's going on.
