thanks for your reply , appreciated
will have a look at the timing , never gave it a thought , i set it up , 20 degrees inital & 34 degrees total , all in by 35 hundred , vacume advance set up to 50 degrees at part throttle opening at max engine vacume ,
will have a look the weekend ,
