That is very nice. Clean and neatly done. My project may be a little rougher as I am filling in most of the holes in the firewall with sheet steel. My Ramcharger is destined for drag race only. Speaking of the brake booster, I cut the unit in half, reduced the diammeter by 80% and have welded the two halves together to make a mount for the two bolt aluminum master cylinder to the four bolt firewall. Manual brakes for me. I got the M/C from Dr. Diff along with the adjustable pushrod.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
