I have a 1985 D-150 with the 30 gallon tank (which is a real joy to fill by the way with todays gas prices ) the small rubber section between the filler neck and the tank has a hole in it, Do I have to get a specific factory part for this or can I just use a section of radiator hose? Anybody else had this problem? If so, how did you fix it?
