Did the IR check and its only about 5 degrees drop. I plan on putting some kind of stat in it when I do get a radiator and I am seriously thinking of replacing the heater core at the same time. I cant remember off the top of my head what it is timed at but I do know I have it spot on. Runs rough when adjusted either way. The fan is a clutch style. With a shroud.
