well time to start a build thread in the next few week's i will be starting the build. truck is a 81 d150, /6 np435, she will be getting a 74 318, hedman header's, edelbrock 4bbl intake, holley or eddy carb. tranny is a 727 with a TF-3 kit installed, truck will also be getting a full 5 on 5.5 swap along with the rear being a spring under axle swap. hei ignition. truck will be a daily driver/cruiser. plan is to build the 318 in it or maby down the road put a big block in her. but right now i think the little 318 will do over all the body is in good shape, maby a few little dings in the fender's nothing i cant fix. here is the day we found her we traded a ford ranger (that we got for free) for her
drive fast, drive hard, DRIVE MOPAR
