I purchased a set of shaft mounted aftermarket roller rocker arms. They are set up for the cup style pushrod end. My 360 had stamped steel arms on shafts and ball ended pushrods. What small block came with the cup end pushrods? Are they close to the length of the 360 pushrods? Thanks
