Note that there are some rules on window nets location. NHRA does not specify where the net has to be but the IHRA rulebook states that the front of the window net must be within 2 inches of the rearmost point of the steering wheel. Most people probably don't care but I am a stickler for meeting the rules.
Also on the mounting... it cant be outside of the cage..
so watch where you put the mounting points... I seen
a guy ahead of me in tech get bumped due to his being
mounted on the outside portion of the tubing... they
dont want the net/and mounts ground off if you flip
up on the side and are sliding on it... that part
is a logical rule
Also if you go with one style net (I forget if its
the ribbon or which) that it doesnt expire for SFI
