Okay, when looking at the tail light stripe on a 70 Duster, I've seen the bottom piece done two different ways and cannot figure out which one is correct? Does the 'v' cut in the stripe point down (which makes for a huge gap between the two) or does it point up (which creates less of of you take a look at this one, you'll see how the 'v' cut points down towards the ground and it makes that massive gap between the two stripes.
http://www.pantherpink.com/fm3180g.htm?load_img=7
