This MP windage tray http://www.summitracing.com/parts/dcc-4120998/overview/make/dodge is labeled for use with center sump oil pans. Any reason it wouldn't work with a rear sump truck oil pan?
Let me see if I can find my box, but I am almost certain I used that tray with the truck pan. I needed the truck pan for the dart because the 402 hit the rack.
I got that tray and drilled some holes to help with oil drain back.
It was a little tricky to get the tray in as the truck pan has a long pickup tube, but it worked fine.
Again, I'll check in the garage for the box, I cannot seem to find my receipt.
Confirmed. This is the tray I used with the truck pan/pickup. Worked fine.
383, Hemi 4-Speed, AlterKtion, D60
