TBI is around 14psi. Uses the same pump at MPFI. Any FI pump will work as long as the regulator controls the pressure.
If TBI uses the same pump as MPFI, then it's a lot higher than 14psi. I think my truck runs at 43psi, but I'd have to get the book out to verify.
**Photobucket sucks**
