Not too shabby, have you tried 34° timing yet? All our SB's love it. Making a timing and spring change together you really can't credit either. Just my .02
Timing started @ 35. I dont think the mono leafs changed et much because 60fts stayed the same. I was looking more at the mph for the hp increase. 112mph then 115 now, same DA @ 1000 ft.
Actually if the MPH went up you are making more power
so the 60' should have dropped some if it was hooking
up right... like I said before.. keep going fatter
till your MPH drops
