Thanks for the reply!
I'm looking at another online diagram of the relays... do I need to have 30 bringing in the 12v and 87 going to the motor? I'm wondering if I have those backwards. Relays are all brand new and I have both doors set up like this right now and neither works, so I am leaning towards wiring.
The actual power window switches all are known working as well.
For the ground, I have that ring terminal going to a bolt in the door... am I correct that the door frame itself is a good ground?
Darren
