...Have you tried a jumper wire to the coil positive and then jumping your starter relay to see if it starts?...-RT
OK, showing my ignorance here, one end of the jumper wire gets hooked to the coil positive, where do you hook the other end of the wire?
To the battery positive terminal or other known 12v source.Hot wiring the coil.
