Well when I got the car back I immediatly started tearing into it. I decided to make it a super nice driver that I could drive in spring, summer, fall, rain or shine. I decided to pull everything on the underside and get everything powder coated. After a bad experience with the first powder coater I finally found a great powder coater named Larry from JIT Coatings in Farmington MN (peabodyracing is his handle here). I am amazed at the work and very happy. Evey piece under my car is coated. While I was working on the rear end I added a rear sway bar from a Cordoba under there and added a clutch Sure-grip in the pig. Here are pics of the
rear:
I had the frame brackets for the rear sway bar made by a fab shop and powder coated
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
