what a pita
- first the aftermarket (china auto zone) turn signal switch with the wire contacts were to long so they did not make contact with the brass buttons in the switch. This prevented power into the circuit.Clipped the contact wires to allow the right fit and powered was transmitted.
- once I figured this out still the front right signal was not working, I metered the firewall connection where the signal comes out and there is nothing for power. The other 3 corners are working.
Now I will try the signal switch test enclosed above to see if its in the switch, at this point thats all thats left. Power is coming thru the flasher and the fuses are good.
I suspect I will pulling the column down for this one.
Thanks for the help
