I'm using one and had the same issue with the adjusting button feeling loose when the bolts were tightened. It doesn't move enough to affect the timing though. Also I bought the timing chain cover from AndyF. And had problems with finding proper bolts due to the design change of the top gear. But after a little all is good.
