The last time I was at the wrecking yard looking at the dodge truck and van row (70's thru 80's) and I noticed that some of the fans on them have a lot bigger blades than the 60's cars ever came with.
You don't want to cut it too close with the gap between the shroud and the outer part of the blade because engines do move around a little with the rubber engine mounts.
