the next thing to do is glueing in the small yellow turn signal lens into the housing. i used a little bit of 5 minute epoxi, just to seal the gaps. don't use to much because otherwise you will see the glue on the inside of the lens. the picture (poor quality) shows the housing standing on the side that faces the driver. sorry again
