the pocket of which you speak...are we talking of spring pocket depth?certainly theres no chance dakota balljoints share stud dimensions with this truck?or even half tons?
If youd search on this site you'd find alt more Lowering info Yes Dakotas share the Same balljoints as your tuck if Not a 4000# axle. The half and 3/4 ton trucks share the Same fribt components unless the 4000# axle rating. Just the rotors change do to 8 lug. There is at least 4 guys on here that used the Dakota Lowering spindles on their trucks. I've got the custom lower control arms available in the for sale section. Just sold the spindles I had planned to use.
Bob Im pretty sure my crewcab has 1/2 by 20 studs.
