...do you HAVE traction problems now? If so, that's impressive with 2.76 gears?
...do you have sure-grip?
I should say that I just bought the car but don't have with me yet. I think it's the stock rear for the 73 charger se 400
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
