i'd throw that comp cam lube in the bin. i used it once, removed the inner spring for the run-in & lost one lobe totally & 2 others were looking sad. when i rang comp cams they said i must have been doing something wrong. yep sure was, i was using their run-in lube. repeated the operation with ARP assembly lube, messy stuff, but the cam run-in went perfectly. that comp cam lube when you rub it between your fingers n thumb dissappears real fast, hardly the hang-around for lubrication qualities that i was expecting. these days it's roller all the way, no more knackered cam lobes for me.
