I checked out all the info given here, thanks for the info guys. The last word is, over $1200 for a new set of eagles now if you have no cores. What a bummer. So back to plan A, get my cores checked when I get home and see what it will cost to have them done up for what I need.
I gave up with the R&D on Eagle heads. The stock intake air speed was too slow from the git go from a lazy intake port.
Talk with Travis and see what he'd charge you to weld up your 5.7 quench pads. I tig'd mine up myself and had Travis milled them down to make them a closed chambered head. With my simple hand port job and using 2.08"int/1.62"exh valves my port velocity was 345 fps vs 300 fps when using an Eagle head.
Jerry Williams.
