Rick...
Any car i have had i tried to set the flash up to be 1500-1700 rpm below the shift point, and around about the torque peak as well. My Duster i shifted at 7000, and i suspect the peak torque was about 5200 or so. The convertor flashed about 5400 or so. Remember as well that the compression you have( or lack thereof) will also effect your 60 foot.Relatively big head, and relatively low compression. Its entirely possible you actually have the convertor pretty darn close.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
