The small 4bbl manifold is for use up to 7000 rpm on a 572 cid engine.DO NOT try to use this manifold on a 604 turning 7500 rpm,it was not designed for that!!!
The large 4bbl is for up to 9000 rpm and/or larger cid engines
Both manifolds need to be port matched and adjusted to deck height,etc.
