Also, when a sprag fails under power, the sun shell can also explode. We had a sprag failure but had a drilled sun shell and aluminum drum. The drum held up but the sun shell exploded. This was about the 60 ft mark where it exploded. Destroyed the case, sunshell and valve body. We went to an A&A Ultra Sprag and have had no problems since.
