But right now the truck has a throttle body on it with a bunch of wires and sensors that are hooked right to the throttle body. My question is if I convert it to carb where's all that wiring and acessories on the throttle body gonna go once there's a carb with not place for all this stuff to hook up?
im not 100% sure how the throttle body wiring harness is without looking at mine. when i did my big block swap in my 87 there was a small harness for the carb. it goes back to the firewall to the main harness and there is a connector. i just unhooked it there and took all of it out as i didnt need any of it. i think the oil pressure wire for the gauge is in it but i used an aftermarket gauge.
