The A518 is a small block trans? Can A518 be mated to big block?
need to convert it with a JW Ultrabell
That's what I did.
have you run it yet ? also did you dial it in ? . the JW I helped a friend put in his drag car needed offset bushings , it was connected to a powerglide , what a nightmare it was indicating the pump bushing thru that small hole on the bottom on an assembled engine .
