Not staying like this for long, found out today that the springs have add-a-leafs in them so I am getting some lift out of it over stock height.
Also the front cross member looks to be the same other than the pickup version is "boxed" in and part of the front suspension bolts to it. Still not sure if I need to change it out, I'd rather not since it has the motor mounts and such...
Ramchargers only real diff in chassis is the length. Suspension etc is the same 4x4 to 4x4 and 2x to 2x. Thats why a Cummins bolts rite in
