71 cuda street car all steel except the hood and front bumper. 440 .030 kb hyper pistons a little bit in the hole, ported 346 heads with 2.14 1.81 valves mp .557 solid cam crane iron rockers m1 single plane 800 cfm carb, 1 7/8 hookers 2 1/2" x pipe aero chamber muffler out the back, 3000 stall manual valvebody 3.91 gear 325 50 et street radial. car went 7.66 in the 1/8th at 89mph with a 1.69 60'. thinking about adding cal tracs since that was the one time the car actually hooked. i feel like the car should be faster but i was hitting high gear right at the lights. should i be expecting more? any tips to shave a tenth or 2?
