Re: ignition-electrical?
#14060
01/13/05 10:24 AM
01/13/05 10:24 AM
i have an FBO coil. recommended voltage to the coil is 10-11 volts. the ru-11 .5 ohm gives me 8 volts, the mopar .25 ohm gives me 6 volts. i tested an MSD .8 ohm it was 7 volts to the coil. the stock 1.25 ohm was 5.5 volts to the coil.
What if you ran two of the 0.25 Ohm resistors in parrallel? Then you'd split the load and should get 12VDC. Or is that too much?
Why don't they just make a 12-14VDC coil?
