The performance carbs have a nylon like bushing installed in the base plate and the throttle shaft rides on that. When it gets worn the shaft leaks gas. Holley sells replacement kits based on the list number of th carb. I would try that before puttin brass in it. Any good machine shop should be able to make this mod if its not already set up this way.
