With the car in the air you need to properly center the control valve...
Looking at the steering box, the control valve housing is the part with the hoses attached... Slightly loosen the two 1/2" bolts that go straight down through the housing into the steering gear.... Now, engine running lightly tap the housing forward or rearward & you'll see it changes where the center position is... By carefully working with it you'll find the proper location.... BTW when your close snug the bolts & then with the steering wheel pointed straight ahead fire the engine up while watching the wheel, if it stays still your done, if it "kicks" in one direction or the other your still not quite there...
BTW when starting the engine make sure your hands are clear of the wheel as if the valve is way off center the steering wheel can spin hard enough to break your arm....
X2 adjust control valve
What you didn't want to type all that out?
affirmative
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
