my standard answer on this is check your grounds. Electrons start looking everywhere for a path to ground when a good one can't be found. All kind of strange things happen. Install toothed star washers on your ground connections, maybe install a designated dash to body ground strap?
Most of the time when attacking a problem like this, your first tendency is to look for a short in the wiring. Most of the time, it is a missing, corroded or painted over ground point. Shorts are easy to find, high resistance grounds a pain in the lower posterior. Good luck. BTW, I would start with the new regulator and make sure it is grounded properly. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
