Quote: I had 1 1/4" of shaft sticking out the end of the trans housing. if I had 1" of yoke to housing clearance the shaft would be bottomed out in the yoke or pretty close to it.
In this case I would slide yoke in till it bottoms out,now measure from center of cap to center of cap,then subtract 1" from your measurement.
