I recently bought a Mikes Powerglide Monster Glide with a Contintental 9 inch race converter,I don't have any real world expereince with them, how often do you guys change the fluids and which type flids do you like? BTW, the car weighs around 2500 lbs wet and the motor makes 687 HP, 5.13 gears in the rear with 17x33x15 tires that are right at 104 inches circumference Thanks in advance
