Hi. I'm replacing the sail panels in my GTX. The new ones from REM are flat and have two faced tape stuck to the top and bottom of the backing on all sides. The perforated material is about 1/2 bigger than the backing material.
1) Is there a good way to form a curve in the backing material? Will the trim force it into shape?
2) Should I wrap the perforated over the top and bottom of the backing?
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
