thanks ron
another thing you could do is make a vertical cut down from where you chopped the back window and then cut across the back below the window and take 2" out of there and lower the back window the same amount as the chop if there is enough room before the body line, then you could keep the back glass stock, just something to think about Ron....
this is exactly what i intend on doing.
