couple of questions???...
-what type of rockers are on there? Stock
-what valve springs were installed for the .509?
-were the pushrods stock? Yes
-was the engine decked or heads milled at all? No
-what pickup/pan/oil pump? Moroso deep sump with 3/8 pickup and a high pressure pump by Melling
-what type of oil and cam/lifter lube was used for breakin? Valvoline 10/30 and the cam lube that came with the cam
I found a receipt for lifters so I may have replaced them after the spun rod bearing.
This motor isn't new, it had about 5 years worth of driving and dtuff on it and wiped the came after a no zinc oil change
More info
MSD ign dist wires etc
Autometer gauges
ARP rod bolts
