Unless you are trying all different exaust combo's and measuring results you have no idea what your gains or losses are. That 8 hp loss was on someone else's combo. you dont have a clue what yours are. It may make less but make more torque. Unless you are running a heads up class just adjust the hp loss with the dial in on the window. That is allot of expence for the small gain.
JAKES AUTOMOTIVE
