so did I and all I can say is check the wheels for roundness and runout BEFORE painting them and mounting your tires, etc. Mine were bad enough that one couldn't even be balanced properly.
Is there an easy "at-home" way of checking for roundness and run out? Will mounting them on an axle and spinning it with a dial indicator riding on the rim work? I guess you'd having to do it both horizontally and vertically? How much run-out and "out of roundness" is acceptable?
