Would pulling the #2 fuse do the same thing as disconnecting the battery? It clears the PCM. Curious if your car is a M6 or A5. Do you run with traction control on or off?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
