have the block sonic checked and 1st check the main caps to see if they are tight in the block we have a wedge block from that time frame that we had program make over sized main caps to fit !!!
Jim is correct,also look at the back of the block just above the bell housing bolts for any indication of a tag being glued on.Many of the street blocks came with a tag:bore to max.4.280 or 4.375.If not as Jimmy said sonic test and do it frequently on the Major and minor thrust.Try and maintain .180 after finish bore.
