wally426ci
You might have to do some more checking around for those. On my 71 they snap into the fuse block similar to the delphi 56 connectors but have the shaped end to accept the fuse ends. I did not encounter these being sold anywhere when I was working on mine.
If you aren't trying to be super slick and make the circuits look factory, you can get blocks that hold any number of fuses you could wire up from a single power lead and then keep the accessory fuse block near the main factory one. The two or three circuits I added, I just put in an inline glass fuse holder under the dash so I don't have to keep both glass and blade fuses in the glove box.
