I'm in the process of purchasing a 1965 D100 pickup with a 318 poly and a 4 speed. I would like to convert it over to electronic ignition but am unsure of what distributor to use. Will one from a la 318 fit? Can I just take the guts out of a small block distributor and swap them into the poly distributor? Will probably use an MSD 6al since I have one on the shelf. Any insight anyone can give me would be greatly appreciated.
Randy
