If your present bearings show no galling or scoring clean, pack and reuse. They will last forever for you if installed and adjusted correctly. One you have done it you will likely never have to do it again with the amount of miles these cars will typically get. IMO stick with the tapered bearings. http://www.moparts.org/Tech/Archive/axle/12.html
